barkest Posted August 22, 2016 Share Posted August 22, 2016 (edited) Hi, I have posted a few things on here and I am now adding a cushion/pillow with a star on it and a uv map. Bear in mind that the file is Educational To use the UV map image then just change it in an image editor (PS for example) and change the texture in VW to this changed image. You cannot change the scale of the texture in VW you will have to do that in your image editor, however you can rescale the object and the texture will also rescale in VW - which is great. Please ask if you need help. Feedback is always welcome Edited August 22, 2016 by barkest Quote Link to comment
