roof layer elevation not linng up
Andrew Mac
I am creating my roof and when looking at it in a front view, it doesn't sit at the correct elevation- It is a lot higher- What went wrong?
I set my my first floor elevation at 0 with an 8'-1" wall height- Then I set my roof layer at 8'1"=
However something is wrong because it does not sit at 8'1" elevation-
Ant suggestions
  • 4 years later...
Had something similar happen. What I found in my situation is that when you create a roof, even though you created it on the roof layer, it is automatically placed on the floor layout level. All you have to do is reposition it by dragging it up and into place. Does not change any other settings or elevations - they all stay correct.
