AlanW Posted August 14, 2016 Share Posted August 14, 2016 Hi you can run a 2d network and don't get this, then as soon as you add a node with reference to a Z Co-ordinate you get this error. Makes it hard when wrapping to an object. As every time you change the OIP you get this error. Any ideas.??? Quote Link to comment
Kevin McAllister Posted August 14, 2016 Share Posted August 14, 2016 Alan, Can you post an example that does this? I've only see this when using a Marionette object. I think its related to them being hybrid 2d/3d objects by default. Marionette hasn't really been 2d/3d/Layer Plane/Screen Plane proofed, that's for sure.... Kevin Quote Link to comment
AlanW Posted August 14, 2016 Author Share Posted August 14, 2016 Kevin, The current fence network does it. if you try to wrap it to an object it will object, and give the message. Quote Link to comment
Kevin McAllister Posted August 15, 2016 Share Posted August 15, 2016 Interesting. The last version I downloaded wraps fine on a Mac.... KM Quote Link to comment
AlanW Posted August 15, 2016 Author Share Posted August 15, 2016 (edited) mmmm. not doing it at the Office PC but like the level marker you were working on same issue. Hopefully 2017 will fix unless there is a cache file I need to trash to clear the issue. Are you able to convert it to an Object with Control Geometry? Edited August 15, 2016 by Alan Woodwell Quote Link to comment
