AlanW Posted August 13, 2016 Share Posted August 13, 2016 Is there a way to run a few Name objects one after the other using one group or any way. Need to be able to run all the internal walls from one network but if you try running 2 together they run ito each other. Any suggestions????? Thanks Quote Link to comment
Kevin McAllister Posted August 13, 2016 Share Posted August 13, 2016 (edited) Alan, I thought connecting your name nodes to an Ordered List node and feeding them into a single one of your wrappers would work. In theory it should, but it doesn't. It somehow gets confused. It would work for a single wall which is interesting. Something downstream is not letting go of the first wall. I did find a workaround (image attached) which does work. Maybe Marissa or Sarah can tell us why the other way doesn't work. Kevin Edited August 13, 2016 by Kevin McAllister Quote Link to comment
Patrick Winkler Posted August 13, 2016 Share Posted August 13, 2016 Hi Alan, I can't look into your file at the moment so I'm not sure what the problem is. But maybe the chunk node can solve it. name-nodes -> chunk by the number of name nodes (using get length) -> ... Patrick Quote Link to comment
AlanW Posted August 13, 2016 Author Share Posted August 13, 2016 Thanks, yea seems a tricky one. was hoping you could add them together in the name node similar to what you can do in the Any node with vectors to draw a line. Will play with both suggested options. Thnaks Quote Link to comment
