Benson Shaw Posted August 12, 2016 Share Posted August 12, 2016 (edited) Context: z value of Site Model Pad objects can be adjusted via OIP, or with several drawing tools/commands: Drag (eg in a side view, screen plane), Move by Points, Move 2d & Move 3d. Problem: If the pad elevation is adjusted with the drawing tools, the pad(s) moves, but the OIP elevation field does not update to new value. Bug? Working as Designed? Or did I miss something? Test: In a drawing with a site model, create a pad, eg a Rectangle>Objects from Shapes>Site Modifier>Pad. Slope and Grade Limit not necessary for this test. Pad defaults to Elevation 0. Switch drawing to any side view & Screen Plane Move the pad up or down with any of the drawing tools or commands: Drag, Move by points, 2d Move (y value), 3d Move (z value). Note that OIP continues to report z=0 Same situation if the z value is adjusted sequentially via OIP, then drawing tool, then OIP, etc. The elevation field only reports the results of the OIP moves. Who cares? •OIP should report the Pad z value relative to the drawing z=0. •Drawing tools can move a selection of many pads in one go. OIP method requires select/move each pad separately. -B Edited August 12, 2016 by Benson Shaw Quote Link to comment
