Tom Klaber 736 Posted September 7, 2016 ALSO - small CSS thing: The button on the custom stream creation page is white on white. Quote Share this post Link to post
PVA - Jim 2,390 Posted September 7, 2016 Not your fault, the Edit button was accidentally hidden by the CSS styling. To edit for now, select the "Reason" field and then hit Enter, it will submit the edit. We will fix this. The white button is apparently a similar issue and will be corrected, but for now it can be pressed normally. 1 Quote Share this post Link to post
PVA - Jim 2,390 Posted September 7, 2016 22 hours ago, Kevin McAllister said: You're enjoying the direct control, aren't you Sooooo when I changed the group names? I broke the fix the web team was halfway through implementing that would bring the attachments from older posts back. As a result, the attachments being restored is now delayed. Looks like I should have had a meeting and not pressed a button in that particular instance. My fault. Quote Share this post Link to post
Kevin McAllister 1,153 Posted September 7, 2016 26 minutes ago, JimW said: Sooooo when I changed the group names? I broke the fix the web team was halfway through implementing that would bring the attachments from older posts back. As a result, the attachments being restored is now delayed. Looks like I should have had a meeting and not pressed a button in that particular instance. My fault. If it makes you feel any better, I like the singular versions much better KM Quote Share this post Link to post
Art V 405 Posted September 7, 2016 On 06/09/2016 at 8:11 PM, JimW said: See now, they titled me User Experience Manager when what I really wanted was Fleet Admiral. Why not go for "Master of the Universe"? Quote Share this post Link to post
PVA - Jim 2,390 Posted September 7, 2016 4 minutes ago, Art V said: Why not go for "Master of the Universe"? #ItsTimeToRethinkMyCareer Quote Share this post Link to post
Tom Klaber 736 Posted September 7, 2016 Vectorworks Auto?? I like it. Quote Share this post Link to post
michaelk 511 Posted September 7, 2016 oy. That is a really bad idea. :-) 1 Quote Share this post Link to post
PVA - Jim 2,390 Posted September 7, 2016 "Maryland man found crumpled in smoldering wreckage, barely alive, mumbling incoherently about graphics cards." No worries, only works while in Park Quote Share this post Link to post
Markvl 189 Posted September 8, 2016 I suppose with that car you could just say engage and away you go. Quote Share this post Link to post
Art V 405 Posted September 8, 2016 6 hours ago, Markvl said: I suppose with that car you could just say engage and away you go. To boldly go where no Vectorworks user has gone before? Quote Share this post Link to post
EAlexander 261 Posted September 8, 2016 Hi Jim, For some reason the subtext on the forum has disappeared - or rather - looks like it is set to white font color? The info is there if I highlight/select it. Just an FYI -evan Quote Share this post Link to post
PVA - Jim 2,390 Posted September 8, 2016 I still see the text, if you restart the browser or clear it's cache does it still not appear? I know they are still poking many things in the back end and I've had to wipe my cache a few times for the admin panel. Quote Share this post Link to post
EAlexander 261 Posted September 8, 2016 Hi, Restarted and cleared cache - still no joy. Should have mentioned that I'm on Chrome Version 52.0.2743.116 (64-bit) using El Cap 10.11.6. Didn't change anything major over here - just drafting e. Quote Share this post Link to post
EAlexander 261 Posted September 8, 2016 even weirder - I get the same issue in Safari - so I'm guessing somethings up with my machine Will reboot the whole thing and report back. Quote Share this post Link to post
PVA - Jim 2,390 Posted September 8, 2016 Does it look the same in Safari or Firefox? Your setup is the same as mine. Anyone else seeing the same weirdness on the main page? Quote Share this post Link to post
rDesign 473 Posted September 8, 2016 (edited) I see it too using Firefox 48.0.1 on OS X. I selected the text so you can see it has a white font color. Maybe the Web team is pushing back against the lack of love for white space? Edited September 8, 2016 by rDesign Quote Share this post Link to post
PVA - Jim 2,390 Posted September 8, 2016 Got it, cleared MY cache and then it started happening, lol. Will alert the web team just in case. Thank you! 1 Quote Share this post Link to post
Mickey 37 Posted September 9, 2016 Oh sooooooo white. It's harsh on my eyes. I'm not a fan. Quote Share this post Link to post
PVA - Jim 2,390 Posted September 9, 2016 We're gonna have a dark mode. I've already had to lower my monitor brightness a smidge. Quote Share this post Link to post
EAlexander 261 Posted September 15, 2016 On 9/8/2016 at 4:21 PM, JimW said: Got it, cleared MY cache and then it started happening, lol. Will alert the web team just in case. Thank you! Hi, I still have this behavior in Both Chrome and Safari - any word, or is it just me? Quote Share this post Link to post
PVA - Jim 2,390 Posted September 15, 2016 No change to it yet, we have a few things that are going to all be restyled at once. This issue is linked to the CSS for the page so I can't manually override it without causing chaos and destruction. Quote Share this post Link to post
EAlexander 261 Posted September 15, 2016 No worries - just making sure I'm not losing my mind. Thanks. Quote Share this post Link to post
PVA - Jim 2,390 Posted September 16, 2016 22 hours ago, EAlexander said: No worries - just making sure I'm not losing my mind. Thanks. This should have been fixed a bit ago now, give it another look. 1 Quote Share this post Link to post
