Creating an IMAG viewport?
Ethan R.
Hi -
Before I go into "research mode" (Trial & Error!)
I want to create an IMAG viewport.
Figuring I can
- Create a Viewport from a rendtrworks camera
- Copy that viewport to a sheet layer with a screen
distort / adjust that camera viewport to match the skew of the new viewport?
Anyone have a better idea?
Thanks!
Ethan
I think Ethan wants to take a camera view of an event space and insert that camera image onto the screen objects he's placed within the event space in order to create a rendering. For example, if his rendering is a wide shot of the stage with a speaker at the podium with screens behind, he wants a close up of the speaker on the screens rendered from the same environment. Essentially a rendering nested into a rendering.
I've done this before but I rendered out the camera view as a JPG and turned it into a texture to apply to the screen - so a two step process.
(IMAG is live video at an event inserted into the live video presentation - https://en.wikipedia.org/wiki/IMAG)
Kevin
  • 5 weeks later...
One way to do it is to render the camera view save that image as JPG or PNG. Even if you save it as PDF I think you can copy the picture and save it on your desktop.
Then create a new texture in Vectorworks import the image to that texture and assign that texture to your screen.
I hope this helps.
I take advantage of this conversation to share the learning experience on using now integrated Camera Match in 2017. It is a matter of placing a fix point and align 6 vanishing lines to a photo. Maybe small adjustment at the end. What I like about using camera match is that I can control the rendering style and not always trying to go for Photorealism. (See images)
