AlanW 522 Posted August 9, 2016 (edited) Hi, Attached is a Marionette object that produces a quick set of steps. Thanks to Domc's node that i Messed with. Apologies Dom. I was looking for an easy way to make a set of stairs and modifying this seemed to do the trick. The actual stair network is small. this file has a few lights that are adjustable in the OIP also as a marionette object to liven up the scene. Turn on the light in the visualisation pallet and select. you have adjustments in the OIP Thanks In the second File the steps are regulated so if you have over 18 risers you get a warning note and also if the 2 X the riser + going >700 or < 550 you get a warning to change. You will only see the text in top plan view in this file. Just shows how you can control the User. Edited August 9, 2016 by Alan Woodwell Quote Share this post Link to post
