digitalcarbon Posted August 8, 2016 Share Posted August 8, 2016 Rotating pipe on joint Quote Link to comment
Benson Shaw Posted August 9, 2016 Share Posted August 9, 2016 That's good rotation control, but the pipe cut profiles only match in the original position or 180º of that. One fix is to make a square cut on the grey pipe, close to the bevel joint. Select the little cut and the purple assembly, and rotate them together about the axis of grey pipe. -B Quote Link to comment
digitalcarbon Posted August 9, 2016 Author Share Posted August 9, 2016 Benson, you are correct. once we did it, it got scrapped and we are doing basically what you said. Quote Link to comment
