More intuitive animation tool
P Retondo
It's pretty difficult and frustrating to set up an animation in VW. Been basically unchanged for years. I wish I could do the following: do a walkthrough onscreen in OpenGL, save the path - including stops, rotation of viewpoint, and spins - then have that path generated in a list and be intuitively editable to tweak the speed, duration of various events, viewer height, etc. Then an easy setup for type of rendering and a quick preview capability, and, of course, faster multi-processor capability for rendering! With reliable and stable progress updates, and the ability to stop and start processing at any point in the rendering.
4 answers to this question
Agreed. The good news is that this is already on the list of things that are almost assuredly going to be updated, but it won't be in 2017 specifically.
What you recommend is basically what I proposed, with the added caveat that "recording" your movements in this way should create an actual object that shows the 3D path of the camera with widgets along that 3D path showing where the camera is facing at any given time along that path, letting the user tweak angles and directions as well as the speed and movement curve (acceleration/deceleration curves, I mean) between each widget/view.
With the advent of the Gaming mode controls for walkthrough and the 3DConnexion becoming more widely used, recording the users walkthrough path becomes a logical next step for animations.
Animationworks is what I would want as well, made by OzCAD who also make the lovely Windoor!
http://www.ozcad.com.au/products/animationworks.php
Don't know why things like this arent simply bought and bundled in more often, but it might become a more common practice going forward. It certainly makes sense to quickly get functionality in that has already been established and polished for years.
