Marionette Endless possibilites
AlanW
When I first started out with Marionette it was a struggle to understand how to implement the nodes and the main problem I had was how to use it that was different from the program.
Well all of a sudden I can see the huge value in Marionette in the recent networks that have produced a building from a simple polygon. Once you have the object generated without using a control geometry method the file is as if you drew it the long way, all walls roof etc all work as if you drew them the long way, so saving lots of time.
Its a start, but now I am seeing that I can sketch a plan and have it developed quickly domestic and even commercial with the curtain walls.
With apartments I see being able to have a series of symbols for standard kitchens, bathrooms etc and generate a series of different layouts and be able to generate a model quickly. I can scrip in to have take offs for all the items in the model. You are only limited by your imagination as to how far you can take Marionette. Its just exploding and I see so many things to do with so little time.
Stay tuned.
And get into it its infectious.
Edited by Alan Woodwell
