Ordering inputs in the OIP - possible bug?
If you take a Point3 input node and number it at the beginning of its name (e.g.. 1Coordinate) so it shows up first in the OIP, it only displays the Z field. If I leave the number off I get X,Y,Z as expected but I have no control of the field placement in the OIP. Is there something different I should be doing? Is this a bug?
Edit - I posted this in the wrong forum, it was meant for the Marionette forum. Could a moderator move it please....
Kevin
ubbthreads.php?ubb=download&Number=16036&filename=Screen%20Shot%202016-07-30%20at%206.16.36%20PM.png
Edited by Kevin McAllister
  • 2 weeks later...
  • Marionette Maven
I currently don't have a definitive answer, as I haven't even found the documentation where this is described as a method to order nodes.
Could you point me to where you've found this info? I'll also consult with the engineer on it, but first I'd like to see what the intended method really is.
Hi Marissa,
I think I learned about it in the forums but it is also here -
in the official Marionette introductory videos by JimW.
Kevin
