AlanW Posted July 29, 2016 Share Posted July 29, 2016 Hi, Expansion on the straight Grab rail. This is a U shaped. Hope it all works well. Still the issue of moving in oblique view that it may disappear. See how you go. Quote Link to comment
AlanW Posted July 30, 2016 Author Share Posted July 30, 2016 Hi here are the 3 grabrail types, still with a few issues like disappearing when moving. Click on grab rail and you will see OIP with parameters to change. Copy the hand rail and keep it in your library,Dont delete it as you will lose it. If you rotate it and it forms a closed ring just hit enter again and it should go back, if not just rotate it again. The use of 3D poly seems to be more stable that the 2d poly, but you cant curve the corners as the change 2d vertex doesnot work on the 3D. Will have to code a 3D node. The L shaped has a drop down menue to flip right or left How to stop the rail from snapping to the wall? How to stop it from closing sometimes, Just change a rotation number it will resolve itself. And the Disapearing well may try the 3D poly. And suggestions to make the more stable welcome. Quote Link to comment
