AlanW Posted July 28, 2016 Share Posted July 28, 2016 (edited) Hi, Attached is a file with a series of networks that I have complied for residential use. Most are objects so they have control geometry that you can change and symbols to swap in and out. The grabrail, internal screens, paving, gutter, Crown moulding, skirtings, trees on plan & 3d, internal lighting track(lights turned to invisible)click on each object and adjust in the OIP that appears. Make sure you don't name any symbols the same otherwise you will swap symbols with strange effects. Test them out, thanks. Edited July 29, 2016 by Alan Woodwell 1 Quote Link to comment
Jkellett Posted October 13, 2016 Share Posted October 13, 2016 I don't appear to be seeing any attached files :-( Quote Link to comment
AlanW Posted October 13, 2016 Author Share Posted October 13, 2016 (edited) Yep this hasn't been fixed yet, so have a look at this post and location as these links work. HTH https://forum.vectorworks.net/index.php?/topic/43251-nodes-available-on-the-marionette-resource-share-forum/ Make sure you go to the bottom of post and then come back up to find the last ones i place there and they work as of 14.10.16 Edited October 14, 2016 by Alan Woodwell Quote Link to comment
