We use automatic drawing coordination in part to automatically match the sheet titles in our custom title block with the sheet layer names. These are set as multi-line fields using the # suffix. However, we really wish these two limitations would be eliminated:
1) The only way you can enter a multi-line title is through the Edit Title Block dialog. You presently cannot enter a multi-line title by editing the sheet layer name and you cannot enter a multi-line title using a worksheet – please make it possible to enter multi-line fields in worksheets and when editing sheet layer names (presumably using a soft return)! After all, worksheets are obviously able to display multi-line fields, so why not allow us to edit them there as well?
2) Only the first line of multi-line titles is used as the sheet layer name – please allow the full title to be shown in the sheet layer name!
Markus Barrera-Kolb
1 answer to this question
