johnharley Posted April 29, 2002 Share Posted April 29, 2002 Question: What is the best type of polyline to use for drawing contours? For instance, if you are tracing them from a scanned document. I would also like to be able to export them later to AutoCAD and have them show up as fully editable p-lines. Quote Link to comment
Guest Posted April 29, 2002 Share Posted April 29, 2002 If you want to use polylines in VW for creating a DTM, you will need to convert them to 3d polygons and assign a z height to them once they are drawn. Quote Link to comment
Kevin Posted April 30, 2002 Share Posted April 30, 2002 Katie;Exactly what is a polyline? I see a line tool. I see a polygon tool. In your example, am I correct in this understanding: 1. Scan document.2. Import document.3. In a separate layer, trace the contours with "polylines", (whatever those are).4. Select all and choose the "Convert to 3d Poly" command.5. One, by one, select each 3d poly and in the Info Palette set the "Z" height. Thanks for your help. Quote Link to comment
Guest Posted May 1, 2002 Share Posted May 1, 2002 A polyline is a line that can be closed and given a fill, or it can be left open with or without a fill. It's generally a line, but allows you to incorporate vertex points giving you greater flexibility. It can be drawn wtih 4 mode types, straight and 3 types of curves. The polygon tool only allows you to draw straight lines - no curves. However, you can convert objects to a polygon which can then be extruded. Or you can convert them to 3d polygons, which can be manipulated along the z axis as far as height. If you are scanning an image, yes the best way to go about it would be to do as you said. Scan imageimport image to it's own layerTrace over the contour lines in a new layer making that your exisitng data layer with the polyline tool. Then you can convert them to 3d polygons and specify the z height for each one. Then you can make your site model based on the data provided. Quote Link to comment
Andrew G. Buck Posted April 23, 2004 Share Posted April 23, 2004 "convert them (2D polylines) to 3d polygons" Can you point me to the tool to do this? Thanks, andy Quote Link to comment
