Brooklyn Posted July 21, 2016 Share Posted July 21, 2016 I'm putting a hatch texture on a 2-D drawing at 1:48. When I make it into a Viewport on a composite sheet the hatches do no scale. Can this be fixed? Thanks. Quote Link to comment
michaelk Posted July 21, 2016 Share Posted July 21, 2016 If you edit the hatch in the RB there is a setting for Units: World or Page. If the hatch is set to page, it will appear to be the same size no matter what the scale. If the hatch is set to world, it will scale. hth mk 2 Quote Link to comment
Jonathan Pickup Posted July 21, 2016 Share Posted July 21, 2016 (edited) You can scale hatches using the Attribute Mapping tool, or you can use your advanced settings in the viewport settings to scale hatches. http://learn.archoncad.com/2015/02/21530/vectorworks-tip-213-attributes-editing-hatches/ http://learn.archoncad.com/2015/01/21359/vectorworks-tip-201-attribute-palette-create-hatch-from-local-mapping/ http://learn.archoncad.com/2015/01/21271/vectorworks-tip-199-basic-tools-local-mapping-a-hatch/ Edited July 21, 2016 by Jonathan Pickup Quote Link to comment
