I would like a real world simplify Polyline / Polygon tool that simplifies while maintaining an overall shape and key anchor points (i.e.. 90 degree corners / fillet corners etc.). So often I encounter profiles with too many points but using the existing Simplify Polys can't do enough without completely changing the shape. I end up rebuilding it manually instead.
It needs to maintain key points / shapes. Maybe this is done by the user choosing anchor points or by a user defined "smoothing" angle.
It needs to recognize when there are too many points on a continuous smooth curve. Maybe the command needs to work on user selected segments (ie. a marquee selection of points) of a polygon / polyline.
It needs an option to recognize common changes (ie. a fillet transition between two segments at 90 degrees) and ignore them when simplifying.
It needs to recognize a change in direction (ie. the transition point on an S curve) and maintain the points creating these changes.
Kevin McAllister
Kevin
9 answers to this question
