There should be more control over site model labeling.
1. Dimension override of the document units in case you want to use decimal feet instead of architectural. With control over precision.
2. Distance between labels of the same contour. Since the default is to add a bunch of labels and you have to spend time manually removing them, a setting that allows for more placement control.
