CarlJdP Posted July 6, 2016 Share Posted July 6, 2016 (edited) I would like to create a custom worksheet function to return a value from a range of worksheet cells - Like vlookup() in MS Excel. For now though I will settle for returning the th value in [*args]list To my knowledge the closest I can get to that is the following =RUNSCRIPT(13, 'lookup.py', 2, 1, 2, 3, 4, 5) Where: ------------- > 13 - Is the location of 'lookup.py' in this case AppData\Roaming\Nemetschek\Vectorworks\2016\Libraries > 'lookup.py' is the name of my script > 2, 1, 2, 3, 4, 5 are the arguments i'm trying to pass in lookup.py: (current) ------------- def lookup(i, *args): >>>return args[i-1] """ Do I need to call lookup(i,*args) here as well? as the function has only been defined and not run above """ Or should I change it more to something like this: -------------- def lookup(f_i, *f_args): >>>for a in f_args: >>>>>>args.append(a) >>>return args[i-1] i = 0 args = [] lookup(i, *args) Please Help. How do I make this work? Edited July 6, 2016 by CarlJdP Quote Link to comment
DomC Posted July 7, 2016 Share Posted July 7, 2016 (edited) Do you want get the output in your OS Terminal or somewhere out of Vectorworks? That is to high for me, but I am very interested on this possibilities too. As I suppose, that the args method is not loaded in an embedded python. So maybe we have to somehow initialize this first. But as I told, this could be a very dilettantish comment. Edited July 7, 2016 by DomC Quote Link to comment
DomC Posted July 9, 2016 Share Posted July 9, 2016 OK, forget my comment about your args. I thought you want to have access to the sys.argv command line arguments. Quote Link to comment
DomC Posted July 9, 2016 Share Posted July 9, 2016 (edited) Hi I think, we have to specify the args in the worksheet scripts. Like this arg1=vs.WSScript_GetPrmReal(0) arg2=vs.WSScript_GetPrmReal(1) I tried to get all args with a while loop args=[];i=0 while vs.WSScript_GetPrmReal(i) !=None: #Endless loop, attension! args.append(vs.WSScript_GetPrmReal(i)) Don't try this. You will never be able to open your document again. Because Worksheets script automatically actualize at open document (which seems to be a nice feature ...) but If you have an endless loop in your script you will have to wait endless :-) Or maybe it's because the vs.WSScript_Get******* ist not very liberal, if you get wrong value type. A String instead of a float as example? Edited July 9, 2016 by DomC Quote Link to comment
DomC Posted July 9, 2016 Share Posted July 9, 2016 Hi Carl I made an example. Attached to this post. Hope, It can help you finish your project. Code in the Worksheet: =RUNSCRIPT('Script-1', A2, B2, C2, D2, E2) Code of the Script i=0;arg_len=1;args=[] while arg_len >0: arg = vs.WSScript_GetPrmStr(i) args.append(arg) arg_len = len(arg) i=i+1 vs.WSScript_SetResStr(str(args)) Quote Link to comment
