minotto Posted June 28, 2016 Share Posted June 28, 2016 Hi, I rendered a model in "Realistic Exterior Final" a couple of times and each time the Palm tree in the back comes out shifted. Does anyone know what is causing this? The tree is an image prop. Could that have something to do with it? Thanks Quote Link to comment
Benson Shaw Posted June 28, 2016 Share Posted June 28, 2016 Unlikely, but, are there 2 superimposed image props? Delete one. Better approach is to Isolate for trouble shoot. Copy/Paste-In-Place that tree image prop into another drawing. Render with each test idea. •If the isolated file does not render correctly, post the file to the forum for others to test. •Looks like 3d elements are not scaling properly. •Look at it in Top/Plan. Crossed planes look correct? Any duplicate planes? •Is it a symbol? Edit 3d to see what elements are in there. •Long way from drawing origin? Move a copy to origin & test render. •Same result in OGL or other render modes? •Try a custom render with some parameters hi, others low. -B Quote Link to comment
minotto Posted June 28, 2016 Author Share Posted June 28, 2016 Thanks Benson. You really covered everything. It turned out that there were 2 image props at the same point. I don't know how that happened, but problem solved. Thank you. Quote Link to comment
