Chris Dordoni Posted June 27, 2003 Share Posted June 27, 2003 Hello, I find that measuring in an isometric view does not produce correct measurements, even though I am using snaps. Also, moving objects in an isometric view, again using snaps, does not work as I would expect, since the objects are not snapped at the same point in the other views, though the isometric view appears correct. Am I missing something? Regards, Chris Quote Link to comment
Chris Dordoni Posted June 30, 2003 Author Share Posted June 30, 2003 I can set up working planes to move and snap my objects, though it does not really make it any easier than just changing the view, move and snap. Chris Quote Link to comment
Chris Dordoni Posted July 9, 2003 Author Share Posted July 9, 2003 OK - I discovered that VW only allows accurate dimensioning or measuring in a 3D projection view set to Oblique Cavalier 45 or Oblique Cabinet 45. I can live with that, but it would be real nice if I could dimension or measure in an Isometric view (no distortion). Chris Quote Link to comment
