aozhouyyq1982 0 Posted June 22, 2016 Hi all, I use png files in VW, such as tree symbol, but when i export to pdf files, there always show sharp white edge around images... anyone knows how to fix this issue??? see attached screen shot thanks a lot Quote Share this post Link to post
PVA - Jim 2,383 Posted June 22, 2016 If you export this same area as an Image rather than a PDF, do you see the same line? Quote Share this post Link to post
aozhouyyq1982 0 Posted June 22, 2016 Hi Jim when i export to image files,other problem shows up: the image i use as "hatch" show white edge frame... see attched please Quote Share this post Link to post
PVA - Jim 2,383 Posted June 22, 2016 Understood, I have seen this a few times before. I am fairly positive there are changes coming to address this, but I am unaware of how to work around it in the meantime when using images that have an alpha transparency. Quote Share this post Link to post
aozhouyyq1982 0 Posted June 22, 2016 Thanks a lot. hopefully, VW can work it out soon. Quote Share this post Link to post
Benson Shaw 564 Posted June 22, 2016 Same - I get the white border when export images. This goes back many versions, and is a royal pain if exporting for use as source for image texture -B Quote Share this post Link to post
aozhouyyq1982 0 Posted June 23, 2016 can fix this by exporting to image files, but you need to drag all images back to pdf again in the end. I just want to explore some better ideas... thanks anyway Quote Share this post Link to post
