etweed Posted June 25, 2003 Share Posted June 25, 2003 We have an existing worksheet set up to read certain fields of a record format for easy export. We have added a new field to the record format. In the worksheet, we added a column, and then used the same type command as the other columns: =('record name'.field name) however, when the command is entered, it only repeats it for each of the selected criteria instead of actually reading the field value. We so far have tried quitting VW, and even restarting the mac in hopes it would recognize it as existing. Anything else we can try? OSX VW 10.1.2 Quote Link to comment
etweed Posted June 25, 2003 Author Share Posted June 25, 2003 UPDATE: We took out the space in between 2 words in the field name and it started working. Unfortunately, the field name actually does have a space in it, and one of the other columns in the worksheet that did work (and still does) has a space in it. So a blanket "don't use spaces" is not an acurate assessment of the problem. We still don't know why it works/doesn't work, but for now, it is working. et Quote Link to comment
