jchan Posted June 17, 2016 Share Posted June 17, 2016 Hi there, Any one know how to get rid of the line between the columns on different floors on elevations/sections? I am using the BIM model to generate the sections and elevations, but the lines between the continues columns do not look good. Quote Link to comment
zoomer Posted June 17, 2016 Share Posted June 17, 2016 I always thought the typical way in VW, to hide unwanted lines, would be drawing a filled rectangle over these. As I remember there was mentioned something about Walls not getting extra lines between stories. If so, maybe that has to be added to Columns and is a Wish or Feature Request. A workaround could be to draw the Columns from the lowest Story to the full height over all Stories as one part. That way you will miss these in other Stories Floor Plans but could draw 2D counterparts that will not disturb your 3D BIM Model and (overall) calculations. Or Maybe draw the Columns on a separate Layer so that you can add these to all related Stories Floor Plans in Viewports. And depending on the viewport's draw/render style, playing with crease angle could help in some cases ? Quote Link to comment
