Angular dimensioning
In VW 2016 I have a 3D model that I'm looking at in right side view. In Annotations mode, I go to dimension the pitch of the roof. I select the Angle Dimension tool, but it does not work. I have to draw a line along the roof pitch and another line that is horizontal, then it works fine between these two lines. I don't have to do this to take linear dimensions. Why do I have to do this for angular dimensions or any other non-linear dimensions? Do I have a preference turned off somewhere? It seems like this is so fundamental I must be doing something wrong.
Thanks,
MHBrown
The Roof Edge should be recognized - I'd class that as a bug.
In the meantime choose the 3rd mode (Reference Lines Mode) of the Angular Dimension tool and with 3 clicks draw your baseline and a point on your roof edge.
The 4th click will place the dimension.
Note, the Slope Tool (also in the dim/notes Palette is useful for specifying Rise/Run.
ubbthreads.php?ubb=download&Number=15610&filename=Screen%20Shot%202016-06-16%20at%209.06.50%20PM.png
