Hide Database Headers on Export
ericjhberg
One nice feature would be to have the option to check a box to "Hide All Database Headers" upon the export of a sheet layer.
I know there are scripts to hide all the database headers, but it would be nice to incorporate this functionality into the export process to ensure that no headers end up visible in exports.
4 answers to this question
+1
I can't think of a reason to ever have the database header open on a worksheet inserted into a drawing. Maybe someone has a use case for that. I wonder if we couldn't just have all database headers collapse when the worksheet is inserted, and open when editing.
To remind myself, I've found it helpful to turn that script into a menu command and put it under the File menu near Print and Export.
mk
Mike
I think everybody's worksheet wish lists go several versions back :-)
If anyone wants to try a script solution, there are probably several versions of the close database header script out there. This is the one I use. (Make sure you set the language to Python). You can easily add it to your workspace as a menu command or just run it from the resource browser.
def CloseThatHeader(h):
WkShtResource = vs.GetWSFromImage(h)
vs.SetObjectVariableBoolean(WkShtResource, 82, False)
vs.RecalculateWS(WkShtResource)
vs.ForEachObject(CloseThatHeader, "T=WORKSHEET")
mk
