AlanW
Code not calling
Hi, is there any reason why this code is not calling?
I am sure I copied it right.
Thanks
def fib2(n): # return Fibonacci series up to n
"""Return a list containing the Fibonacci series up to n."""
result = []
a, b = 0, 1
while a < n:
result.append(a) # see below
a, b = b, a+b
return result
f100 = fib2(100)
f100
If I add
print (f100)
I get a print out but I thought this calls the list without the need to print?
Edited by Alan Woodwell
Hi Alan
Where are you running your script?
In the script editor for vectorworks?
or the Python IDE?
If in the script editor, the print function displays only if an error has occured and you inspect the error.
I normally use the vs.Message() or vs.AlrtDialog() calls to query variables in code. both need whatever variable to be of string type.
in this case it would be:
vs.Message(str(f100))
or
vs.AlrtDialog(str(f100))
If in the IDE: I'm running your script from the Python 3.3.3 Shell (Windows 10) and both methods work. ie calling f100 and also print(f100) shows the list of the Fibonacci sequence
Edited by twk
Hi, running it on my iPad.
And using Python 2.7 app
I am still learning how to code and understanding the indenting etc, so I am on a steep learning curve.
I am doing purely Python at present.
Thanks
ahh ok,
well if its running from a module(.py file, in your case 4.6-04.py), I believe you have to call the 'print' function to display it in the python command prompt.
If you're entering commands directly in the prompt, calling a variable like f100 will display its value on the next line, regardless of calling print or not.
Thanks, I got that now but am sure I will be asking a lot of Noob questions soon.
