Sunday Posted June 6, 2016 Share Posted June 6, 2016 Morning - First forum post. I have a site model that is set to 3D mesh solid - but when i cut a section or view with clip cube - it's hollow. Any suggestions to fix this would be appreciated! VW architect with RW 2015 (Must get around to upgrading!) Thanks Heaps! Quote Link to comment
zoomer Posted June 6, 2016 Share Posted June 6, 2016 No, a site model set to 3D mesh solid isn't a 3D Solid at all. It just looks similar in VW (only), as long as you look from above. I do not know any way to get a 3D Solid from a VW terrain model. Quote Link to comment
Benson Shaw Posted June 6, 2016 Share Posted June 6, 2016 The Extruded 3d Contours simulates a solid terrain with solid sections. But that's not always a useful format for sections. There should be a way to add a fill to the site model or at least to the sections. At least some easy way to apply the paint bucket tool. -B Quote Link to comment
BG Posted June 6, 2016 Share Posted June 6, 2016 If you select the site model & give it a solid white fill in the attribute palette, it will show as solid in a section viewport. Still shows as hollow in clip cube though. Quote Link to comment
zoomer Posted June 7, 2016 Share Posted June 7, 2016 The Extruded 3d Contours simulates a solid terrain with solid sections. -B If you select the site model & give it a solid white fill in the attribute palette, it will show as solid in a section viewport. Thanks, didn't know (or expect) that. Quote Link to comment
Benson Shaw Posted June 7, 2016 Share Posted June 7, 2016 If you select the site model & give it a solid white fill in the attribute palette, it will show as solid in a section viewport. Still shows as hollow in clip cube though. Thanks, BG!! I was testing with the clip cube, which, as you say, does not accept the fill. I should have tried the section VP, too! More notes: •Any color fill assigned to the site model shows up in the section viewport - white, blue, etc. •Color fill also colors the site model surface in Top/Plan view. White is often a good choice. •Rendered 3d view displays the surface color as either the solid fill assigned in Site Model Settings>Graphic Properties, or as the texture assigned in Site Model OIP Render tab. But this doesn't affect fill in the section VP. -B Quote Link to comment
gester Posted June 12, 2016 Share Posted June 12, 2016 (edited) the terrain model is a solid (even if it's called 'a mesh solid'), or at least it interacts in solid operations with other solids. otherwise the cut'n fill calculations wouldn't be possible in real time and wouldn't be updatable. rob Edited June 12, 2016 by gester Quote Link to comment
Diego-Resuelvectorworks Posted January 30, 2019 Share Posted January 30, 2019 There is a fix to this issue? I still have the same problems Quote Link to comment
