Door Transom alignment
Amelia S
7 answers to this question
I had not attempted this before, but no it does not seem possible to me either. I'll move this to wishlist and file requests for offset controls that would allow this.
If possible; could you post an example image of a real world door you are trying to emulate where this occurs? (examples like that help the request move faster, but are not absolutely needed)
A way to achieve that now would be to create a Symbol containing the Door object w/ Transom and if needed a modeled Jamb Extension & Trim.
Then place a door in position in the wall but in the Door Settings>General window select your new Symbol.
Not exactly, Just create a door in a blank space on your drawing. Adjust the settings until you get it the way you need it. With the door selected Modify>Create Symbol.
Now place another door in your wall using the door tool. In the OIP>Settings>General>Use Symbol Geometry>Browse and select your new Symbol from the little window that appears.
