twk
Third Party Development; Project Management
Greetings all,
1.Third Party Development
-would be great to have a section somewhere on the Dev Wiki or here on the forums where third party plugin developers can goto, to request for additional procedures/functions to the existing API calss (eg Viewport Class Overrides!), and also to see a roadmap of upcoming changes to the existing API (eg a number of calls are dropped from version 2012). To help us prepare for the yearly releases. Unless this is already available that I don't know of.
2. Project Management.
-our office has just started using the Project Sharing feature, and it has been running smoothly so far. With the ability to comment on every change/commit a user does has been a great way for us to track what everyone doing.
It would be great if this commenting feature could be added to non-project sharing files as you can add comments/notes/remarks to your file that your working on, and go back through the history of that particular file and see what you've done and when.
Cheers
Tui
Edited by twk
5 answers to this question
Marking this to revisit later after some other projects I have going are completed that it may dovetail well with.
Thanks Jim, which part? The Project Sharing / Third Party Development part?
Tui, what about using the redline tool for Project Management. You can annotate to the changes that are need and the date that the notes was added, then you can also see what date the change was made, and there is a report already built into Vectorworks to report the work needed and when the work was completed.
