Patrick Winkler
Batch Converting - Open, Change and Close Files with python
Hello,
I'm working on a script which changes the units off all VWX files in a folder.
The Problem is that the file opens to late when the script is already finished. I also tried it with the sleep () command.
Is there a way to open a file and make it active within a function?
def main ():
   # Get File
   succes, path = vs.GetFileN('', None, None)
   # Open File
   if get_OS_Code() == OS_WIN:
       # Windows command
       os.system('start' + path )
   else:
       # Mac command
       os.system('open  ' + path )
   # Set Units
   Millimeters =     7
   Centimeters =   8
   Meters = 9
   Kilometers = 10
   vs.Units (Centimeters)
   # Save the File
   vs.DoMenuTextByName("Save", 0)
   # Close the File
   vs.DoMenuTextByName("Close", 0)
If you're on the Mac, use AppleScript to handle opening and saving. VW provides an apple script command to run a python script.
-Josh
