Dimension Input to String
I'm working on a marionette script that can do the following
  • Take dimension inputs.
  • Make a shape base on those inputs.
  • Make a text box next to the shape with the dimensions and other specifications.
I'm having trouble converting the dimension value into a string. Does anybody know of an easy way to do this?
Here's what I've tried so far. I've attempted to make a node for VS.Num2StrF but I'm not having any luck. If I hard code the value directly into the function it works.
vs.Num2StrF(12.000000000000002)
If I try to pass a variable, then it doesn't work. Am I making a simple mistake?
vs.Num2StrF(self.Params.dim.value)
Edited by NeonClear
