Drain Object Modifier for Slabs
Tom Klaber
I do a lot of flat rooves here in NYC. IT would be great if there was a drain object that you could drop on a slab and then the slab would modify to slope to it. Maybe this modification could then be controlled like a roof - where control points could change the slope and you could decide if you wanted the drain slope to be additive or subtractive from the current slab.
I only add this next part because of your new irrigation tools...if it could be taken a step further to have VW help calculate the catchment and the drainage capacity - even better!
2 answers to this question
