HEengineering Posted May 3, 2016 Share Posted May 3, 2016 We have tried this in 2014-2016 with no luck. We have been sent files in a DWF format. Vectorworks shows this as an import option but Ive tried with multiple files and continue to get the same error. I have attached the error that shows up along with the File Im trying to import. Any idea why the DWF wont import? Note: I attempted to upload the file but it will not allow me as it states the extension is not allowed (DWF) I have changed it to a dwg just to upload. You would have to switch it back top DWF. Any help would be appreciated. iMac (Retina 5K, 27-inch, Late 2014) 3.5 GHz Intel Core i5 16 GB 1600 MHz DDR3 Quote Link to comment
Art V Posted May 3, 2016 Share Posted May 3, 2016 It looks like there is an error in the implementation of the DWF import. You may want to file a bug report. Another program that I have also uses the Teigha libraries and can import dwf files, there it worked so I have saved it back as a dwg file that you can import into vectorworks. (see attached file below) If you know what this file should contain you can check if the import went correctly or that something is missing. Quote Link to comment
AlanW Posted May 3, 2016 Share Posted May 3, 2016 I get a report that the file has an error or corrupt. Try getting another file, never normally have any issues with this task. Quote Link to comment
Art V Posted May 4, 2016 Share Posted May 4, 2016 I get a report that the file has an error or corrupt. Try getting another file, never normally have any issues with this task. My other cad program imports the DWF, so there are two possibilities: 1. The file itself is ok but it contains something that VW cannot handle. 2. There is an error or an object that the Teigha library cannot handle but the other cad program ignores it and imports the rest of the objects. If it is the former then getting a new file will not solve the issue. If it is the latter then getting a new file may or may not help depending on whether it is an error or an unsupported object that is causing the import to fail. Which is why I suggested to the OP to check the converted to dwg file to see if the contents are as it should be. Maybe it could be possible to have an option to ignore (yet) unsupported objects in dwf (and other) files to at least have something imported. Especially if it is a limited number of objects that are not relevant that cause the import to fail. Quote Link to comment
HEengineering Posted May 4, 2016 Author Share Posted May 4, 2016 What was the other program you tried? We even tried this with AutoCAD 16 LT. and still no success? Ive tried a few different files and they all seem to react the same. We have over 30 of these a client has sent us and we can't view them, let alone open them. I an try and post another file, But I expect the same results. I also tried this in VW 14,15,16 Quote Link to comment
HEengineering Posted May 4, 2016 Author Share Posted May 4, 2016 Also I tired the converted site. Still no luck Quote Link to comment
HEengineering Posted May 4, 2016 Author Share Posted May 4, 2016 After trying a few more files we were able to get this going. For whatever reason a majority appear to have been corrupt. Tho we did get quite a few to import as well. Not sure if the issue lies with that particular file, or VW. Seems to be file related at this point. Quote Link to comment
Art V Posted May 4, 2016 Share Posted May 4, 2016 The dwg file imports ok into my windows version of VW. Quote Link to comment
gester Posted May 5, 2016 Share Posted May 5, 2016 have you checked this below? https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=183510 rob Quote Link to comment
