jeandm
Loft Surface
Hi all,
Does anyone know how to loft by list of curves rather than by group?
I am trying to loft between the rectangles located along the Red curves here.
Thanks!
Hi jean,
the VectorScript 'CreateLoftSurface'-Function only accepts groups.
If you don't want to use the group node you have to do the grouping inside the loft node.
But could you rather tell us what problem the group node is causing you?
edit:
I played around with it a little bit. The problem seems to be order of the rectangles coming into the chunk node. You can see this by using my print point order node.
Edited by Patrick Winkler
