N_Duch Posted April 18, 2016 Share Posted April 18, 2016 I'm working on Vectorworks 2016 and currently modeling a new residence that's designed to comply with passivhaus standards. We've decided to build the house with SIPS panels which come in both 4' and 8' widths, and I'd love to be able to count up how many panels are necessary and the height of each panel (It would be great to be able to look at elevations of each panel as well, though I have a feeling I may be asking too much). I'm currently using a 2D rectangle symbol to frame out each panel and then running a report on the numbers of each 4' and 8' symbol — though I have a feeling there's a better way to do this. Any thoughts? Quote Link to comment
AlanW Posted April 21, 2016 Share Posted April 21, 2016 (edited) Hi, Sorry for long wait I had to relearn this and yes its possible to do all the above and more with Records. Maybe this is what you are already doing??? Refer to tutorial HTH If you click on row 2 and drag the Sum icon to the top of the column it will sum as per attached so you can see the size of each panel , how many etc and you can create your own criteria. If you add an image function to a column you can show the image in different scales and format. BUT it really struggles with Open GL. Edited April 21, 2016 by Alan Woodwell Quote Link to comment
Guest BillV Posted March 7, 2017 Share Posted March 7, 2017 I have been to a Passivhaus Conference for the last 4 days. It is clear that this concept is gaining momentum especially in Germany, Ireland and England and China. We are seeing even large commercial projects such as blocks of Student flats (Vienna) 20 story social housing in China, a leisure centre with swimming pool in Exeter and a large teaching block at at Polytech in Ireland. Whilst not all use SIPS many do in fact use this method. Ironically a major US manufacturer at the conference said "I can export all my panels to Revit, Autocad, Sketchup (which has a PHP add on module) and to Archicad" There was NO mention of Vectorworks. I approached Robert Anderson two years ago to enquire id VW would consider SIPs but he felt that Architects would prefer to draw walls and leave it to the SIPS manufacturers to then work out the number of panels, I strongly suspect that if we do not consider this then Archicad will come up with this solution. We are the only software with Passivhaus surely the addition of SIPS is a must have! Quote Link to comment
Raj Posted January 15, 2018 Share Posted January 15, 2018 I already Create 1 drawing here, And I already create report for wall core area but its not the exact area,, Its showing only wall internal Area. How to Calculate the Corner Wall Area. Please Find the Attachment file and solve the error reports.vwx Quote Link to comment
