pdrake2126 Posted April 15, 2016 Share Posted April 15, 2016 hello, i'm getting prompted that someone else on our network is using my serial number. well, someone was and now they're not, but the software is still giving the warning and no matter what i do it won't go away. does anyone have an answer for this? thanks Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted April 15, 2016 Vectorworks, Inc Employee Share Posted April 15, 2016 Reboot all machines that have Vectorworks installed on them. If after doing that you still get the error, click the button to get more info on the user that is causing the conflict, this will give you the username and ip of the conflict. If it gives you your OWN username and IP, it often means you are connected to a single network via two network adapters, this can happen if you have ethernet as well as wifi managed by the same router. Quote Link to comment
