Check if Object is a Container
Hello,
I need to check if a object conatins other objects.
Therefore I wrote this function:
def isContainerObj (obj):
   return vs.FInGroup(obj) != vs.Handle (0)
It works but vs.FInGroup will return a error Message to the console when the objects is no container.
Has someone a more elegant solution for this.
thanks
Edited by Patrick Winkler
  • Marionette Maven
What if you check the type of the object you're querying to see if it's a group or a symbol or another object type that could qualify as a container? That should let you know if it will have any "children".
Still a little clunky, but I'm sure there aren't many other object types that would qualify as a container.
  • 1 month later...
