Set IFC Node not responding to List Node Input
Guest unlimited
Guest unlimited
Hi,
I've been experimenting with the Set IFC Node and am encountering an issue if I use a List Node to control the inputs.
The attached file includes a simple script showing the issue ( and a similar benchmark script without the list node which does work).
Can anyone see if I am doing something wrong or does this node just not accept List based input?
Many thanks,
Martyn
  • Marionette Maven
Attached is a file with an explanation of how lists work with Marionette as well as a way to manipulate them to behave how you would like.
The trick here is using the "Mix2" node. It is a very powerful node that is often overlooked, but also very important for cases like these.
Please don't hesitate to ask any questions.
