zoomer Posted April 13, 2016 Share Posted April 13, 2016 I want to refresh my votes by my currently personal Top 10 of most annoying things in VW. Please fix : 1. Extrudes : flipped Top Cap/Face of Extrudes (So also Face Normals mess in Stair/Slab Geometry) 2. RW C4D/FBX/DAE Exchange : Unwanted Duplications/Ranaming of Materials. When a Material is assigned to Elements or Classes, export and assign this Material only to all Elements that have assigned that Material directly or by Classes. Use the Name of the Material for Material Naming and don't add anything to it for readability. Restrict Material Creation for Class Fills to only those Colors when same Colors assigned multiple Times. (Maybe add Add an Option to assign one Default Material only) If no Materials assigned, give an option to suppress Material Export completely. Keep Names of Image Textures even in VW internally. 3. RW C4D/FBX/DAE Exchange : Add an Option to Group all Elements of a whole Class inside of each Layer. If possible even an Option to export all those Elements into a single Mesh Item, while keeping Vertices welded for each Object separately. 4. Worflow : Need of double-ENTER and double-ESC when there are no 2 steps to do. 5. Workflow : Inconsistency in need of -/+ in Numeric Translation Entries (Move by Points doesn't need -, Drag or 3D Modify do need -) 6. DWG/IFC : Arbitrayry Scale and Position Issues or Geometry Loss in IFC and DWG Imports/Exports although no additional scaling is visible/recognizable in VW OIP Element Properties. (BTW Those problematic geometry can also cover Camera Views or Lights when Rendering in VW) Loss for Export/Re-Import in general. 7. DXF : Missing Front+Back Faces of Window Frames Missing Top and Bottom Faces of Slabs Missing Top and Bottom Multi Extrudes (Seen when exporting and re-importing or in imports in any other 3D App) 8. Open Elements : prevent Fills for non-closed Polygons and Polylines until closed (BTW I miss a Multi-Line Tool instead + Auto Closed Polygons) 9. 3D Modify : Missing "Lock to Selected" Element for 3D Modify Tool 10. Move by Points : Missing Continuos Mode for "Move by Points" Tool (1st Click : from point, 2nd Click : to point, 3rd Click : to point 4th ....) Preventing use of "Numbers of Copies" when in Move Mode (I would prefer 2 separate Tools/Icons) Quote Link to comment
0 zoomer Posted April 14, 2016 Author Share Posted April 14, 2016 Sorry, I forgot one (and would therefore abandon on # 8.) 8. (new) Meshes : The selection behavior of Meshes, deviating from all other elements, where crossing only parts of a Mesh Geometry by selection marquee forces a selection of that mesh item. Which makes selection of other parts impossible when any Mesh is near. And deselecting Meshes with another Shift+Click is impossible too. It needs at least 2 SHIFT+Clicks, if it works at all. Quote Link to comment
0 zoomer Posted May 19, 2016 Author Share Posted May 19, 2016 Current Top Ten : 1. Symbols : Can't select Symbols by Click when set Classes to "Show snap others" only. Marquee selection possible only. 2. Show/Hide Grid Grid not visible in Top Plan as hidden by Slab Fillings ! 3. Snapping Snapping Problems when Placing Symbols. Snapping Hint Cubes not appearing and Grid Snap unavailable. Restart necessary. 4. Slabs Missing red section surfaces in OpenGL Clip Cube, just horizontal Surfaces. (I can be happy that it works in section viewports) 5. Slabs In Sub Edit Mode, no surrounding geometry visible (like in Symbol or other Sub Edit Modes) Can neither see where to, nor snap to anything at all. 6. Extrudes Partly Flipped Face Normals (Top or Bottom Cap). 7. C4D/FBX Invisible Layers will not get exported. No option to export whole file. 8. C4D Symbol Instances do not have assigned the Symbols (any) Class. No Visibility control possible. 9. FBX No Instancing of Symbols supported. Exports as normal geometry, but unfortunately packs all these elements into a Null Object / Locator Object which makes things meaningless complex and hard to edit. 10. C4D/FBX No Option to Export all Classes elements in one Mesh Item or at least put in a Group. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted May 19, 2016 Vectorworks, Inc Employee Share Posted May 19, 2016 Current Top Ten : 1. Symbols : Can't select Symbols by Click when set Classes to "Show snap others" only. Marquee selection possible only. 2. Show/Hide Grid Grid not visible in Top Plan as hidden by Slab Fillings ! 3. Snapping Snapping Problems when Placing Symbols. Snapping Hint Cubes not appearing and Grid Snap unavailable. Restart necessary. 4. Slabs Missing red section surfaces in OpenGL Clip Cube, just horizontal Surfaces. (I can be happy that it works in section viewports) 5. Slabs In Sub Edit Mode, no surrounding geometry visible (like in Symbol or other Sub Edit Modes) Can neither see where to, nor snap to anything at all. 6. Extrudes Partly Flipped Face Normals (Top or Bottom Cap). 7. C4D/FBX Invisible Layers will not get exported. No option to export whole file. 8. C4D Symbol Instances do not have assigned the Symbols (any) Class. No Visibility control possible. 9. FBX No Instancing of Symbols supported. Exports as normal geometry, but unfortunately packs all these elements into a Null Object / Locator Object which makes things meaningless complex and hard to edit. 10. C4D/FBX No Option to Export all Classes elements in one Mesh Item or at least put in a Group. I suggest splitting these up, 1, 3, 4, and 6 seem like bugs or file issues to me. 2) Added to existing request for overlaid grid display option. 5) This SHOULD be visible if you enable Show Other Objects in Editing Modes within Vectorworks Preferences under the Display tab, if not please let me know. 7) Submitting request now. 8 and 9) I will check on this with engineering. I do not know if these are file format limitations or not. But if you have seen other software maintain symbols within the format then it is likely something we could implement as well, I am simply not familiar with it personally. 10) Submitting request now. 1 Quote Link to comment
0 zoomer Posted May 19, 2016 Author Share Posted May 19, 2016 Besides 1.+3. what you sorted as bugs, nothing new that I hadn't mentioned in the last years already. But thanks if re-queueing these again. Fixing 6. would indeed solve a lot of export problems as this Extrude Modul also influences geometry creation in Stairs, Windows, Doors, Slabs, ... (Looks like "Solid Additions" and Generic Solids work fine for C4D/FBX) 5. No, all Slab Boundary or Modifiers Modes, unlike Symbols or Group Editing, work in disabled "enable Show Other Objects in Editing Modes". Switching by the quick pref Icon doesn't have any effect. Can't remember VW 2014 anymore but am sure that never worked in VW 2015-2016 8. OK = C4D Problem. I see it doesn't assign the Original's Layers even when creating Instances directly in C4D. But maybe there is an option from VW Export to force this (?) Currently that means, you set your Objects Class to invisible in C4D and your original Object disappears - but all its Instances stay visible. 9. FBX is capable of Instances (works in Modo out and back in) Neither C4D nor VW export Instances by FBX, VW's C4D Export brings Instances into C4D, C4D can not import Instances by FBX Thanks a lot ! Some other missed Features in C4D, needed from a VW exchange view, to get full VW feeling in C4D : (If there is any influence in this direction too) - Layers (VW Classes) should be sorted alphabetically (or overwritten when changed in VW, as Layers names get "locked" after been rearranged manually) - You should be able to assign a Material to a Layer like VW Class, to all members of that Layer. Quote Link to comment
0 zoomer Posted September 16, 2016 Author Share Posted September 16, 2016 On 19. Mai 2016 at 3:55 PM, zoomer said: Current Top Ten : 1. Symbols : Can't select Symbols by Click when set Classes to "Show snap others" only. Marquee selection possible only.NOT SOLVED ! 2. Show/Hide Grid : Grid not visible in Top Plan as hidden by Slab Fillings !NOT SOLVED ! Grid should be visible in general on top of Elements In Top Plan View in Design Layers, maybe by 20% Opacity only. 3. Snapping : Snapping Problems when Placing Symbols. Snapping Hint Cubes not appearing and Grid Snap unavailable. Restart necessary. 4. Slabs : Missing red section surfaces in OpenGL Clip Cube, just horizontal Surfaces. (I can be happy that it works in section viewports)SOLVED 2017 5. Slabs In Sub Edit Mode, no surrounding geometry visible (like in Symbol or other Sub Edit Modes) Can neither see where to, nor snap to anything at all.NOT SOLVED ! 6. Extrudes Partly Flipped Face Normals (original 2D geometry needs to be flipped).NOT SOLVED ! 7. C4D/FBX Invisible Layers will not get exported. No option to export whole file.NOT SOLVED - Export Class/Layer Settings needed, like a Viewports has. 8. C4D Symbol Instances do not have assigned the Symbols (any) Class. No Visibility control possible.Problem by Maxon C4D, low priority 9. FBX No Instancing of Symbols supported, although FBX supports instances. Exports as normal geometry, but unfortunately packs all these elements into a Null Object / Locator Object which makes things meaningless complex and hard to edit.Pity but low priority 10. C4D/FBX No Option to Export all Classes elements in one Mesh Item or at least put in a Group.SOLVED 2017 Quote Link to comment
0 zoomer Posted September 16, 2016 Author Share Posted September 16, 2016 On 13. April 2016 at 7:43 PM, zoomer said: 2. RW C4D/FBX/DAE Exchange : Unwanted Duplications/Ranaming of Materials. SOLVED 2017 Keep Names of Image Textures even in VW internally. NOT SOLVED ! 3. RW C4D/FBX/DAE Exchange : Add an Option to Group all Elements of a whole Class inside of each Layer. SOLVED 2017 If possible even an Option to export all those Elements into a single Mesh Item, while keeping Vertices welded for each Object separately. 4. Worflow : Need of double-ENTER and double-ESC when there are no 2 steps to do. NOT SOLVED ! 5. Workflow : Inconsistency in need of -/+ in Numeric Translation Entries NOT SOLVED ! (Move by Points or Drag doesn't need - 3D Modify do need -) 6. DWG/IFC : ??? NOT SOLVED for DXF ! = complete mess Arbitrayry Scale and Position Issues or Geometry Loss in IFC and DWG Imports/Exports although no additional scaling is visible/recognizable in VW OIP Element Properties. (BTW Those problematic geometry can also cover Camera Views or Lights when Rendering in VW) Loss for Export/Re-Import in general. 7. DXF : NOT SOLVED for DXF ! = complete mess Missing Front+Back Faces of Window Frames Missing Top and Bottom Faces of Slabs Missing Top and Bottom Multi Extrudes (Seen when exporting and re-importing or in imports in any other 3D App) 8. Open Elements : prevent Fills for non-closed Polygons and Polylines until closed NOT SOLVED ! (BTW I miss a Multi-Line Tool instead + Auto Closed Polygons) 9. 3D Modify : Missing "Lock to Selected" Element for 3D Push Pull Tool NOT SOLVED ! 10. Move by Points : Missing Continuos Mode for "Move by Points" Tool NOT SOLVED ! (1st Click : from point, 2nd Click : to point, 3rd Click : to point 4th ....) Preventing use of "Numbers of Copies" when in Move Mode NOT SOLVED ! (I would prefer 2 separate Tools/Icons) Quote Link to comment
zoomer
Please fix :
1.
Extrudes :
2.
3.
4.
Worflow :
5.
Workflow :
6.
DWG/IFC :
7.
DXF :
8.
Open Elements :
9.
3D Modify :
10.
Move by Points :
6 answers to this question
