AlanW 489 Posted April 13, 2016 (edited) Hi, Could someone show me an example how the "Surface from Nurbs" node fits into a network please. Thanks Edited April 13, 2016 by Alan Woodwell Quote Share this post Link to post
Marissa Farrell 428 Posted April 13, 2016 I think it needs to be touched up. I don't think it was implemented correctly. Give me a bit and I'll try to update it/produce an example for you. Quote Share this post Link to post
Marissa Farrell 428 Posted April 13, 2016 Here's a file with an example. I'm still not fully comfortable with the process involved, so I might not be super helpful if you have questions, but I can try. I have noticed, though, that this only appears to work if it's in a Marionette Object, it's been failing on me if I just run it as a network or wrapper. I'll be sure to look into it. I modified the currently existing Surface from Curves node to accept an input of curves, in this example I only used one. I don't know how it would work if you did more? Again, this procedure currently is over my head. I can TRY to answer any questions you may have. Quote Share this post Link to post
AlanW 489 Posted April 13, 2016 (edited) Marissa, Thanks for this, the node I have in the drop down menu has a closed start where this one is open. That may explain a lot of my problems. Thanks Will see how I go So i placed it in but no surface, will re look at it tomorrow. Thanks Edited April 13, 2016 by Alan Woodwell Quote Share this post Link to post
Marissa Farrell 428 Posted April 13, 2016 Remember, Alan, I only have it working in a Marionette Object, I can't get it to work if I just run the script! Quote Share this post Link to post
AlanW 489 Posted April 13, 2016 (edited) Marissa, Thanks again, I must read more carefully, "Marionette Object" and Yay all good. But I used the Shell Solid node. Will play with the surface node to see what happens. Thanks again. Second file shows it all works when changing the Control geometry. :) Edited April 13, 2016 by Alan Woodwell Quote Share this post Link to post
AlanW 489 Posted April 14, 2016 (edited) Marissa, Figured out the other networks, Interesting that some shapes work with convert to polygon then extrude and others work with Shell Solid. Think I came across this issue before where Native objects work different from constructed ones. Also i swapped your surface node with a Shell Solid node and could get it to work also. I like the way you closed your polylines points, same start and end just loop the wires. Nice! Edited April 14, 2016 by Alan Woodwell Quote Share this post Link to post
A_Wiese 0 Posted June 19, 2017 Has anyone moved this node issue??? SURFACE FROM CURVES?? or has anyone found a work around Quote Share this post Link to post
ezgi 0 Posted February 5, 2018 Hello, Is there a solution to surface from curves yet? It is a very vital problem that I keep encountering in my work. I for some resaon can not see the files attached to this topic... Quote Share this post Link to post
