Hello Community!
This Saturday, April 11, from 9am – 1pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Fairfax
Creating Parametric Shelves in VW/Marionette
Hello,
I am trying to create a series of shelves, or "ribs" where the front profile is defined by a lofted surface. i.e., the profile of the shelves will vary by elevation, and their profile will be defined by this lofted surface. I want to do this in Marionette (already have a script that lofts the curve from 3 NURBS), but, to start, how does one do this manually?
I've created a sample file with two versions, one with the profile curve as a generic solid, one as a NURBS curve. The shelf section is 1" thick, a NURBS curve in both cases. It seems like the "Project" tool in "Add" mode should do what I want, but I can't get anything to work. I've also tried this with two solids in Add, Subtract, Intersect, etc. Any help would be appreciated!
Thanks,
Graham
PS - I've added pdfs of what happens when I try to use "Intersect Surface." It gives me the correct front profile, but no shelf behind it.
Edited by Fairfax
Share this post
Link to post
I got some help, but not out of the woods yet. The "Project" tool does not trim the extra part of the polygon/NURBS curve which is being projected that extends beyond the profile. In fact, it won't project unless the polygon/NURBS curve to be projected is within the profile it is projected onto.
That is one issue to deal with, which could make for tricky Marionette scripting. The second is that it's not clear to me that Marionette even features the proper "Project" tool, as I've noted in another post here. The only "Project" tool I located was in the "Points" section and it does not take a solid and a polygon/NURBS curve as inputs.
Something about all this rhymes with "hugs!" ;-)
Share this post
Link to post
I just heard back from a VW Marionette expert (thanks Sarah!) to try the "Contour" function, which also has a node in Marionette. This is a bit cumbersome because it creates NURBS curves which then need to be converted to polygons to "trim surface" the shelf polygons, which are then extruded, unless there's a more streamlined approach. Thanks!
I am having trouble getting the "Contour" node to work. How do you compute the "point" and "dir" input values from/for a given NURBS surface?
Share this post
Link to post
I've attached a VW file with a couple attempts at getting the "Contour" node to work. I don't know if there's another bug I'm dealing with or just a "short between the earphones" as it were!
Share this post
Link to post
You'll most likely want to leave "dir" alone, the default value will split the surface horizontally.
I'm having a hard time producing an object that will extrude, though. Usually when we use contours, we use it on an object that would produce a closed shape, in this case, it's not really doing that well since you're just doing a surface that was converted to a generic solid.
I'll keep poking it, but I feel like this workflow is probably not going to produce the results you want.
Share this post
Link to post
So here's as helpful as I can be at the moment.
I've mocked up an example using a Hemisphere and contouring to produce "shelves" throughout it. (you'll have to use your imagination on the shelling of the hemisphere ;) )
Your output will be a little trickier, as you have a more difficult contour result. I would suggest attempting to add a vertex on each poly (after converting from your NURBS) to prevent the crossover you'll probably encounter.
If I wasn't descriptive enough here, feel free to reach out to me directly (either through a message here, or by email - which you can find in my profile)
Edited by MarissaF
Share this post
Link to post
Hi,
This got me thinking again and my shelving test seems to work in some areas and not others.
Maybe someone can see a better solution.
Thanks
Edited by Alan Woodwell
Share this post
Link to post
Hey Alan!
Thanks for bringing this up. I, too, have been encountering the problem when converting to Polygons. It appears that some shapes when converted are actually being created as MULTIPLE polygons (you can think of it as each line is now a separate object) and we don't have a "compose" node to fix this problem (something I'm working on, I promise).
I'm not sure what the circumstances are that the conversion fails, as you and I have noticed, it DOES work in some cases, but fails in many others.
You're not doing anything wrong. We just have something weird going on with the back end of all of this. I'll look into it further.
Thanks!
Marissa
Share this post
Link to post
Hi,
I think a solution lays in the use of the create surface from curves node as it worked manually creating these shapes, but I cant figure out how to use it or fit it not the network.
I am sure you can assist.
Thanks
Share this post
Link to post
Hello,
It's been a long time (I've been distracted by work, life, and a major house renovation) but I still have an unfinished architecture studio awaiting a solution to this. Does anyone have any ideas?
Thanks,
Graham
Share this post
Link to post
Hi, You might want to put an image back in as to what you are after, and one of us will see if we can create the network for you.
Attached a lofting shelf option for you to play with. Simple shelving can be achieved a number of ways, Place an image and we can see what we can do.
HTH
Loft & Shelves-01 v2017.vwx
Share this post
Link to post
Alan,
Here's the general idea. The shelves in the back corner have their front profiles defined by a lofted surface, the surface defined by three NURBS curves. I want to be able to adjust the three curves and run the script, so that I can iterate easily and come up with a visually pleasing result.
Thanks,
Graham
sample parametric shelves.pdf
Edited by girwin
Share this post
Link to post
Here's a script that lofts a surface from three NURBs curves and attempts to make contours from it, but it has an error. Any thoughts? The contour function seems to cut contours vertically, rather than horizontally, as I need, but perhaps that's due to the error.parametric shelves v2017.vwx
Thanks,
Graham
Share this post
Link to post
@girwinHi, If you simply want to loft a few Nurbs curves detach the network at the point in the image attached.
Attached is another lofting network that may help.
Loft_Example.vwx
Share this post
Link to post
@girwinHi, I think these will be what you are after. they create shelves from different lofted shapes. It all depens on the type of object you start with and how you change it through the network.
Will do a video on the process and post it on my you tube channel.
Lofting Shelves.vwx
Share this post
Link to post
Alan,
This is great, thank you! I'm going to play with it a little bit and try to introduce a third polygon into the loft - I'll keep you posted.
Regards,
Graham
Share this post
Link to post
Hi Question, If I loft the Torus subdivision i get a slither of shelves and if i convert to poly I get a fill circle and open circle. How would I get full shelves out of Torus??
tHANKS
Lofting_Shelves.vwx
Share this post
Link to post
I've made some progress. Alan, I modified your network to use three polygons to create the lofted surface. I've created three networks, one complete and the other two split, so that one creates the lofted surface and the other creates the shelves. Two problems remain:
1) The "loft" command in Marionette doesn't seem to work for the polygons I've created. Running the second network (to create the loft) will show you what happens with the Marionette command. I've included a manually created loft to illustrate the difference.
2) The network portion that uses the contour node to create the shelves doesn't create a shelf at the bottom of the surface. Running the third network uses the manually created surface to create the desired result. It would be nice if one network could do the whole thing.
Any insight would be appreciated.
Thanks,
Graham
Lofting Shelves v2.vwx
Share this post
Link to post
@girwinBoy, that took a few hours of patience to figure this out. Seems that the issue was the lofts were crossing over and getting out of order. Solution was to use one shape and stretch it to fit the shape i wanted. Seems the starting point of the poly needs to be at the same point and the direction needs to go the same way. See the attached.
Lofting Shelves v2-AW.vwx
Share this post
Link to post
I'll try that, thanks! Any thoughts as to how to get the bottom shelf to appear? i.e. at the very bottom of the loft surface?
Share this post
Link to post
@girwinHI, Change the bottom Elevation setting to Zero. (Bottom Left Node) It sets what level the bottom shelf starts.
You can type in a negative number to get it to start below zero.
Share this post
Link to post
Alan,
It's taken a lot of time, and much more fiddling, but I finally got a result I like. Thank you so much for your assistance. I'm happy I automated this process because it took quite a few tries to get the desired result.
Regards,
Graham
Edited by girwin
Replaced pdfs with screenshots
Share this post
Link to post
@girwinHi, Great to see you got the results you were after. The process pdf & 1 look great, the other #2 pdfs i cant open.
Now you have this network you can use it as a template to do more.
If you have any other things you want to automate happy to look at it.
Share this post
Link to post
The other two were views of the iterations of shelves - glad I didn't do it manually! The process was really quite subtle; small changes make a big difference in the result and/or crashed the script after lofting a curve that couldn't be contoured. I updated my post with screenshots instead of pdfs so the images appear inline. Now I need to build this! Thanks again!
Edited by girwin
Share this post
Link to post
Alan,
Funny you should offer! I'm trying to turn this toward designing a bench and can't seem to change the direction of the contours (I'd like them to run in the Y direction in plan view.) Also weird, when I tried to put the script above into my main design file in VW, it changed the direction of the contours and I couldn't adjust it, so I had a separate VW file, working properly, to generate the geometry and I pasted it into the other file.
parametric_bench.vwx
Here's one more perceptive of the studio.
Share this post
Link to post
