mattao
Help me schedule a task please
Hi
I'd like to program a python script to act every 5 minutes. Meanwhile he is sleeping i'd like to be able to do something else.
I've downloaded web link image, it works perfectly.
I'd like to add a button to Autoupdate the image every 5 minutes if the object is selected.
How to do that?
Thanks
I don't think you can run two scripts at once.
If you're using a mac, you can insert vector script or python into an apple script that triggers on a time schedule. Not sure if that will get you around the two scripts at a time problem…
mk
Thank you michaelk
I was looking to do that inside the python script using a sched or time event. I used time.sleep (300) but doing that Works freeze until the 300 seconds are complete. ( not what I am looking for.)
Edited by mattao
I was talking about using the macintosh apple script to do the timing. So the script would run every five minutes, but in-between Vectorworks wouldn't know that the apple script was running.
Here's an example of a ridiculous script that animates a door opening. It's a vector script running inside an apple script.
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=41994&Number=208989#Post209019
mk
Ok the script you provided works fine, and I think it will do what I need.
Is there a way to trigger a PIO event from applescript? Or from python?
My PIO as a button on the info palette that trigger a specific script.
I'd like to auto trigger this script every 2 seconds.
I got to add i succeed in what I was looking for just by Refreshing my PIObject through a modified version of your script.
But I didn't learn how to trigger a PIO event from applescript or python so I still hope an answer.
Thanks
ResetObject() will cause a PIO to regenerate, which may very well be what the button does. If you are trying to trigger a specific button in the PIO, you can't do that with a script.
Keep in mind that Python and VectorScript always run in the foreground, so you're going to get a slight interruption every two seconds. If you are in the middle of a drawing operation when the script fires, it could be interrupted.
-Josh
