VWX Fundamentals 2016 - Autosave Back-up function ... not backing up!
I was happily working on a VWX drawing yesterday and the software crashed.
As I always have my preferences set to "Autosave every 15 minutes" and "Autosave a Back-up copy" I thought no problem.
But it turned out that the whole document was not saved for several hours. Much time lost.
Why is this happening please? Any ideas?
VWX Fundamentals 2016 v.SP1
On Mac OS X El Capitan v.10.11.3
Edited by Riffus
Thank you for your quick reply.
You have slightly got me there on both questions:
- I am not on a server, but I have been moving things from my computer to and from Dropbox - so that is a possibility.
- The "original save" is also a good question - I take it this is 'a must'.
Your questions may be leading me to the answers so if you could clarify - particularly re: using Dropbox - I would be most grateful.
Best regards
I have had a number of users reporting issues when saving (especially auto saving) to dropbox, but these were mainly crashing or long save time problems that COULD have been related but I think it wasn't the main cause of the problem here. I suspect your issue was the lack of the first save, the first save is indeed mandatory or autosave does not start.
I believe this incident could have been avoided on our end by making autosave prompt the user for the first manual save of the document at the first interval, I'll add this thread to that existing feature request now.
  • 1 month later...
Can I revive this item .. because I just worked on a VWX file on my computer (i.e.: not on Dropbox) and did an hour of work.
It then crashed (often crashes on saving - does anyone know why??)
And left no "back-up" version (anywhere) even though my preferences are set for auto-backup every 10 minutes.
All suggestions most welcome.
Thanks Jim,
I have to say I am baffled because I am a regular manual saver but somehow I had lost an hour's work.
I had secured some saves on that session because some of my changes are there.
Then there is this business of the crashing itself. Which happens very frequently and it happens when I do a manual save. But not every manual save.
Any thoughts much appreciated.
  • 4 months later...
I too have had this happen - today I worked on a survey till midday saved then "saved as" to a new document (to start separate sketch drawings on top of the survey) worked on it all afternoon and had a crash about 4:00. I have lost the survey drawing work (from the morning) and the sketch drawing does not even exist! The back up has the survey from Friday's work (none from today) and there is no backup for the sketches.
Now the really confusing thing is I "saved as" and worked on the sketch drawing for an hour then closed it, shut down VW and went for lunch. Came back opened VW  AND my sketch drawing with NO problems. So it definitely was there!
So the only conclusion I can come to is that VW has crashed and then deleted the sketch, survey and back ups!!
my settings - back up every 5mins, save to folder in same place, don't ask to save, no Dropbox etc
any help would be welcomed!
I have seen some weirdness with Autosave at times. I personally would recommend using number of operations rather than time. This guarantees you're not in the middle of a tool/command when it saves. Mine is set to "Autosave every 20 Operations". I also recommend saving the backups to a different folder/location. All of my backups go into one central folder for a couple of reasons - so I can see at a glance that autosave has been saving when working on multiple projects/files, so i can easily delete backups when they are no longer needed and so I don't need to hunt around to find a backup.
Kevin
Something I have noticed at times when trying to save/copy/delete files is that if Windows is indexing files or generating a preview it may not (auto)save etc. depending on the autosave settings. (e.g. if there is only one backup copy used), until Windows releases/unlocks the file.  It is similar as if the file would be in use by another application/Vectorworks instance or be read only. Autosave will fail but not always provide a notification.
Maybe Vectorworks should get an option to notify the user if an autosave could not be performed/completed?
Edited by Art V
  • 2 years later...
I've just verified this feature has not yet been added to Vectorworks. (As at Vectorworks 2019 SP2)
  • 1 month later...
Hey @Jim Wilson, if you think it might help, can you please reignite or bump this feature request? It seems like a pretty small/easy think to implement and offers great potential benefits / time savings of work lost.
This should already be happening, I think I had Vectorworks prompt me about this the other day. Let me check and make sure.
  • 3 months later...
Hi everyone, I have just confirmed that as of at least Vectorworks 2019 SP3;
Vectorworks now prompts users to save new files - if they have yet to do so - when the first autosave process occurs.
(No autosave can occur / No backup files can be created, unless the file in question has been manually saved by the user).
Edited by Jeremy Best
Added screenshot
