t_and Posted March 7, 2016 Share Posted March 7, 2016 Hello, I have been working for some time with my VW files, and today when opened and created a couple new layers, then I wasnt able to select the objects in the other layers like they are "frozen". In class options I already checked and its setted on select everything. I looked through the forum and found different threads. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=159257 https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=138662 https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=211104 On one they comment about the "Force Selection" option, and yes it does work, but now I need to do it in every different object that its in a different class. Why did this happen? Is there a way to force select everything? Thanks a lot. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted March 7, 2016 Vectorworks, Inc Employee Share Posted March 7, 2016 If Force Select worked, the issue is normally that you have View > Layer Options set to "Show/Snap Others" instead of "Show/Snap/Modify Others". There is a similar version of this for classes under View > Class Options. They're mutually exclusive settings. Quote Link to comment
t_and Posted March 7, 2016 Author Share Posted March 7, 2016 Thanks a lot. I didnt know you could do this with the classe too. Thanks you very much again Quote Link to comment
