Sign in to follow this
t_and
Unable to select
Hello,
I have been working for some time with my VW files, and today when opened and created a couple new layers, then I wasnt able to select the objects in the other layers like they are "frozen". In class options I already checked and its setted on select everything.
I looked through the forum and found different threads.
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=159257
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=138662
https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=211104
On one they comment about the "Force Selection" option, and yes it does work, but now I need to do it in every different object that its in a different class.
Why did this happen? Is there a way to force select everything?
Thanks a lot.
Share this post
Link to post
If Force Select worked, the issue is normally that you have View > Layer Options set to "Show/Snap Others" instead of "Show/Snap/Modify Others".
There is a similar version of this for classes under View > Class Options. They're mutually exclusive settings.
Share this post
Link to post
Thanks a lot.
I didnt know you could do this with the classe too.
Thanks you very much again
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
