ETC ColorSource Spot symbols
The ColorSource spot is physically very close to standard Source4 fixture. You can set the beam and field angles as needed. I've never been religious about matching symbols, probably because I was trained with paper and template with 12 outlines.
The only remaining issue is it's overall light output. The simple answer is to not depend on VW calcs for brightness. (I never do!) Or you can copy that symbol and edit the brightness. There is a good support video on making your own fixture symbols.
Hi folks;
I worked for some weeks last summer updating the entire ETC library, with the assistance and support of the nice folks from ETC. In August I released the ETC 3.8 object library. Of course, they've gone ahead and released even more nifty doo-dads, so i intend to update the library again after USITT. In the meantime, however, you can see gif images of all the symbols on the Field Template website.
http://www.fieldtemplate.com/soft/down_etc_frame.html
all the best,
Steve Shelley
shelley@fieldtemplate.com
plug>
  • 2 weeks later...
