Open GL Viewports
I saw an earlier thread about this, but the question was never really answered. When I do an Open GL render of a perspective view on my design layer, everything looks correct. When I turn this into a viewport on a sheet layer, the same view looks pixelated. I've checked the viewport settings in the Object info and can't find anything that would cause the discrepancy. Thanks.
This is normally because sheet layers default to 72DPI. This can be increased under Tools > Organization > Sheet Layers, select the sheet layer, edit it and then set the DPI to something closer to 150 or 300, then update the viewport.
