Temporary Render Works Deactivation ?
zoomer
Ouch, my abilities end far before Scripting or Programming starts.
My level of abstraction is limited to Marionette Webinar 1.
There would be many modules needed to get disabled to keep the
who RW stuff disabled ?
I think I couldn't even install without RW, I would need a low level serial.
Even the Trial Version is complete.
And have some doubts if even then every RW content of my files would
be really ignored.
Even my attempt to switch to Fundamental Workspace was answered with
an App Crash.
I would like to see what happens if :
I export a VW to Cinema.
- if there will be any Material created from Class Filling Colors
What Tools or settings I will really miss at the end
- like what will happen to the Wall Components Dialog or other Arch Objects
- will Walls with complex Wall Styles (Components) exported as a single Solid.
Will the "Send to C4D" option really be included in non RW Versions now
(Or do you still need to buy ½ C4D (RW) to be able to Exchange with your C4D)
Will FBX Export be available in Fundamentals.
Will there be any differences in how Geometry gets exported in different formats
Things like that.
As currently RW for me produces more problems and extra work as it solves.
PS:
Trying to switch to Fundamental Workspace crashes VW in any Case,
even with only a real blank file open.
Currently you NEED the Renderworks module to export to C4D, even if you had the plugin it wouldn't function if it thought that your license didnt have Renderworks enabled.
However, if you send your test files to tech@vectorworks.net with the list of things to check I can test them here, I have every flavor of Vectorworks at my disposal and can try on the full Designer/RW as well as just Fundamentals on its own.
As far as I know the Export to C4D command was available before I had RW.
The "Send to C4D" = Exchange was RW only.
I think I got the desired result by renaming the Apps Renderworks Folder.
Not 100% sure of course if really all related Options in Dialogs will disappear.
But things like FBX (which I need and every 3D App should have) and Collada
Export are grayed out.
The "Send to C4D" is still there.
It was said some time ago on the German Forum that RW would not be longer
needed anymore to have C4D exchange (from VW 2016 ?)
To me it sounds like you need to work with the local distributor to either find a user close to you who has just Fundamentals or have them do a demo setup for you with just fundamentals so you can see what is available. Or maybe they could get a temporary serial number that only has fundamentals activated.
I don't know why the Fundamentals workspace is crashing. It does not do so here.
As far as I know, the Fundamentals workspace has all of the commands/tools that are part of the Fundamentals license with the possible exception of those in the Legacy folder(s).
I think you are correct.
The rests of RW dialogs that stay in VW bring the hint that my License
is not enough to open things like Visualization Palette or RW Background
which is fine.
But neither Send to C4D nor Export to C4D will work without a crash.
No proof for being RW only, as I think VW w/o RW had the Renderworks
Folder with parts of its content anyway.
But I really like the speed bump for the start of VW.
Thanks Pat.
I can't live without FBX anyway.
Realized that Fundamental will prevent me from Architectural Tools but not from RW anyway.
I can switch to Fundamental Workspace now, as long as I don't have any file open.
The workaround renaming the RW Folder was adequate enough to see what Tools are gone.
If I only knew it myself ....
I upgraded to RW with 2014 as I was not able to export Walls by Components
as DWG or in even OpenGL without RW. That behavior could be interesting now.
I think there was a thread where someone missed his components a while ago.
Wanted to test if non RW Exports to C4D will prevent me from extra complexity
in some way. Or if Refreshing the geometry in C4D will be more reliable.
Will find if Exchange possible at all with the help your List.
The list is interesting anyway. Did not know that I have a Batch Rendering ....
Hi Dave,
I did hide the RW Folder, it deaktivates RW and grays some Dialogs.
Not sure if that workaround will show dialog windows 100% as in
VW without RW.
The Send/Export to C4D Dialogs are still there and active, but will crash VW.
So I assume there may be some parts of that RW folder contents also needed
In plain VW.
